Size of Locker
Size of Locker
I have a 2007 4.6L V8 F-150 and i was looking to get a locking diff. but the only one i can find that will fit my truck is Detroit Locker 225SL56A i was wondering if there is a locker that will fit my truck thats a bit cheaper. thanks
Are you sure you are looking at the right part number? Do you have the HD payload package with the 7 lug axles and 10.25 rear axle or the standard 6 lug 9.75" axle?
Typically the only less expensive lockers are "lunch box" lockers that install in an open differential, from Aussie lockers or Richmond Gear (lock right). Neither of them list an application for the 9.75 rear axle, but Richmond lists a lock right for a 10.25 rear axle as part number 1840. It does NOT list it for the F150 with the 10.25 rear axle, but if that's what your truck has it MAY work, you would need to contact them to be sure, after verifying the axle under your truck.
http://www.richmondgear.com/powertra...lications.html
I had an Aussie locker in a previous truck, and a Detroit in my current truck. My experience was that the Aussie locker was actually smoother, but I cannot say for sure if the lock right is the same.
Whatever you choose, contact Wayne at http://www.diffsonly.com/catalog/
Tell him that I sent you. I bought gears/bearings/lockers for him for several hundred less than anyone else would sell them, I highly recommend him.
Really? I thought they ditched the 31 spline 8.8" in the newer body style (04+). I have never seen one at least. The part number for the detroit locker he posted was for a 10.25/10.50 axle.
So what was the answer? What locker works best with the 4.6L 31 spline 8.8
I have a 2006 F-150XL 4.6L 8.8 rear and Im wanting to put a locker in along with a 3" level kit for some NITTO 325-60-18 TERRA GRAPPLER TIRES. I just want a little better traction in bad weather, Not off road mudding or anything like that.
.... Richmond lists a lock right for a 10.25 rear axle as part number 1840. It does NOT list it for the F150 with the 10.25 rear axle, but if that's what your truck has it MAY work, you would need to contact them to be sure, after verifying the axle under your truck.
RVtec88: As said earlier, your truck has an 8.8 axle most likely (you better check before you buy something). Since you aren't going 'wheeling, I'd recommend a limited slip rather than a locker. More mannerly. IMO, the best would be the DetroitTruTrac... but it's at the higher end costwise. From there, I like the Auburn Gear High Performance, the Eaton Posi and the factory Traction-Lock gets last place in my book (very ineffective).
The "lunchbox" lockers are the cheapest option and the easiest to install, but they can ratchet and bark tires in turns. If you go the Powertrax route, their No-Slip is more mannerly than the Lock Right because it has a synchronizer. Likewise, the Aussie locker is also smoother
