battery light
Old Aug 27, 2010 | 11:29 PM
dirtrider596979's Avatar
battery light
hey not realy sure this is the right catagory for this but....the battery light has been on constantly in my 01 5.4 for the last few days. i checked the voltage and got just over 14. i do have hypertech under drive pullys but ive had them over a year with no problems. if the truck has a momentary drop in voltage will the light stay on constantly like a CEL or will it go off wen voltage is back up? the belt is a new gatorback and the battery is 2 years tops
Old Aug 28, 2010 | 12:34 AM
steven'sf1504x4's Avatar
alternator is bad probly cause that light means something is wrong with the charging system
Old Aug 28, 2010 | 01:03 AM
thats what i thought but im still getting just over 14 volts
Old Aug 28, 2010 | 01:18 AM
is the battery gage droped to with the light on ?
Old Aug 28, 2010 | 01:22 AM
well i would assume that if it has been like tht for a few days that the alternator isnt bad if the truck hasnt died or anything it could just have a bad sensor on it or something but you can take it to advance and have them check it to see if the alternator is bad or not.
Old Aug 28, 2010 | 02:14 AM
James Hopes's Avatar
Actually, the natural voltage of the battery is 12.6V. It can stay at up to 14V for a minute or two after the engine is shut off or a charger is removed.
Old Aug 28, 2010 | 07:52 AM
the battery gauge reads just as high as it ever has and wen i got my 14 volt reading that was engine running and i left the tester on the battery for 5 mins and it didnt drop except wen my efans kicked on but it droped to 13.5 then went back to 14 quickly
Old Aug 28, 2010 | 08:52 AM
jbrew's Avatar
If volts are still Increasing, you have a short. It would be the LG/RD Wire. Trace that one, you'll find it most likely.
Old Aug 28, 2010 | 10:37 AM
by volts increasing u mean past 14? and witch wire is it that i should check? i already replaced the main power wire from the alternator to the battery and that wire had two others in the loom with it and i just taped them up as there own separate harness and hooked them back up
Old Aug 28, 2010 | 03:53 PM
jbrew's Avatar
Right, - If your between 13 & 15 volts, the system is fine. You either have a pin dislodged in the connector , a short or you didn't connect the Green on the other side. As long as you not dropping below 13 at any time while she's running, -it's charging. Yea, you battery is determined healthy right ? Your alternators putting out within spec right ? Sounds like it to me.
Iduno, what do you guys think?
Old Aug 28, 2010 | 05:04 PM
If the light is on and it still appears to be charging adequately, there are 2 possibilities - a wiring issue like Brew is pointing to, or a bad diode in the alternator.
Old Aug 28, 2010 | 08:52 PM
well the orange and green wire are definatley good between the connections is good. im goin to check the plugs and pins tomarrow, if they are all good is there a way to check the diode in the alternator? it looks like the green wire is the one that runs the light is there a way to check the pins it goes to at either end?
Old Aug 28, 2010 | 11:48 PM
jbrew's Avatar
So did you replace the connector as well ? That's not clear. You you got a new harness and two wire were tapped to it. Or did a new connector come with ? Well, regardless, make sure it's like this - Orange - White - Green.
___________
Yea, the harness separated, - show opposite side of connection. Connection at the firewall. Not sure if yours is like mine. This is a 98 pic here, - the 2001 might connect a little differently, but it should be wired the same. My Orange connects to that 20 amp mini and the right to the 12 volt side. Your diagram shows it the same.
You most likely have that all tested out by now lol. I would check all the fuses, if you haven't already.
Good Luck.
