What kind of gears should I run
What size tire are you running? I can give you an idea what it will do to your cruise rpm. If it's the tire size on your door sticker, here are the rpm for the various ratios in overdrive.
mph 3.73 4.10 4.30 4.56
70 2005 2204 2311 2451
85 2435 2676 2807 2977
Personally, I wouldn't go more than 4.10.
Ok well i've decided to go with the 4.30 gears. I have the money ready to buy them. But before i buy. Can you guys tell me everything i'll need and possibly give me some links. I want to be able to walk in a shop and not have to buy anything extra from them. Also quality matters for me i'd like these to last for a long long time. I can handle the install if you guys can just help me out with all the parts. Thanks
I don't know if you'll need to buy an install kit for just gears. I know if your mileage is over 30K and you're swapping in a new differential, a master install kit is generally recommended. You can buy the fluids if you want, but performance shops usually carry it. If you do buy fluids, don't spend $100 on Amsoil or Royal Purple, it's just going to get dumped after the 100-500 mile break in.
Hopefully someone will post that done just a gear swap and not the whole shebang like I'm doing.
Here ya go. Motive gears are really good gears from what i've heard and researched. Not just saying that because its the gears i got, saying it because all the research and talking to ppl/mechanics showed them as being good gears. Motive gears are pre-broken-in. mine were very reasonably priced too.
Here is where i got mine
http://www.americantrucks.com/motive...430-gears.html
installation kit
http://www.americantrucks.com/motive...n-kit-99-.html
unless you have way over 60k, i wouldn't do a masterbearing kit. But of course it wouldn't hurt if you did just cost more.
http://www.americantrucks.com/motive...g-kit-99-.html
Of course there are plenty good brands out there, i just think motive has good prices on theirs. I mean, if you find a GOOD gear set for cheaper than the motives, i'd go with them. I'm a bargain shopper! lol
Goodluck
installation kit
Goodluck
