drivetrain clunk
Old May 26, 2010 | 05:10 PM
prophet136's Avatar
drivetrain clunk
has anyone expirienced a drivetrain clunk or jerk at around 50-60mph? under light load there is a jerk/clunk coming from the drive train. i believe it to be a pinion gear issue but not sure. i was wondering if anyone had this issue and what the fix was. i have 2004 supercab with a stepside bed, 5.4L
Old May 28, 2010 | 06:11 PM
seadog364's Avatar
Yup
I've had it since I got my truck in 04. Seems to be more of annoyance than an actual problem.
Old May 28, 2010 | 07:18 PM
chiefFX4's Avatar
can't remember if this was for stock applications or some of the first edge tunes but there was a problem with the torque converter locking and unlocking. This would seem more like a constant shake or jerk. if it was a factory problem your pcm needs to be reflashed at a dealer.
another possibility is the truck is searching between 3rd and overdrive. this might also be corrected by a reflash of the pcm.
both of these problems seem like a constant shake or jerk though. if this is what you are feeling you can be drastically shortening transmission life.
Old May 28, 2010 | 08:03 PM
prophet136's Avatar
if i drive steady at 50-55 then it is a constant jerking. most of the time though its me getting to 50 then stepping on the throttle then feeling the clunk.
