DriveShaft
Old May 24, 2010 | 10:55 PM
RaceChick's Avatar
Talking DriveShaft
When under moderate acceleration, my driveshaft made a loud clicking noise. After a few days it went from clicking to sqeeking, and now there is hardly a noise at all. On the Driver side rear U-joint there is some grease leaking out. I would love some comments before taking it to the shop..Thank you!
Old May 25, 2010 | 01:09 AM
97XL's Avatar
If you get them replaced make sure they put in ones that have Zirk fittings so you can keep them grease yourself. Takes 5 min. Just keep pumping in the grease until you see it start to ooze out.
Old May 25, 2010 | 06:07 PM
chiefFX4's Avatar
if you have time and some tools it really is an easy fix.
either way, sounds like those u-joints are shot. get it done quick. i had one start to seize in the driveshaft it was getting so hot.
Old May 25, 2010 | 10:15 PM
IR0NS1N's Avatar
Yes get them fixed asap!
Old May 26, 2010 | 09:52 AM
RaceChick's Avatar
I replaced both u-joints yesterday. on the rear, one side was completly greased while the other side was bone dry! you could see the needles starting the wear a patteren. but its fixed and im off driving again. Thank you all for your help!
Old May 26, 2010 | 01:22 PM
Klitch's Avatar
did ya happen to get one you can service? they last longer if you can, and do put a few pumps in occasionally.
