4x2 to 4x4
4x4's have torque-rod suspension for the front end.
IF it is possible at all, you would need to replace virtually everything related to the steering, plus whatever sub-frame-related goodies (back under the front seat) where the torque rods adjust.
THEN you'd need to dink with the axle gearing itself (plus transfer case and special output case for the transmission).
Lastly, the driveshaft to the rear axle is also different.
I'd bet that is is possible if you were to buy a complete rollover for the parts -- but I've never actually looked at the (dis)similarities of the two chassis.
Sounds like quite a project (but you're not the first to ask).
Tell us if you try it; and
Good luck!
Y2K™ Jim
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Good luck!
Y2K™ Jim
They make a kit to change older fords over, but I don't know about new ones. It might be easier if you used a solid fron axle for the conversion.
99 black f150 4x2 ext. cab sport w/4.6 V8. external mods. include:
3" body lift, 3.5" fabtech lift, airaid FIPK, JBA headers, Superchip headlight/taillight covers, wiper schroud, shadeblade, ventshade, bug deflector, bed liner, tonno cover, and Flowmaster Amarican Thunder cat-back system.
internal mods. include:
Pioneer indash cdplayer, 2 8" MTX subs, 400 watt amp, remote start, and aftermarket alarm
<a href="biglongaddress.com/morestuff/yetmorestuff/pagename.html">shortdescriptiveword or words</a>
