?? No 4WD ?? ABS light on any correlation?
Old Mar 4, 2010 | 02:05 PM
TRIXSNK's Avatar
Just bumping this trhead back up ttt as the issue has returned
After thinking it was fixed and a few trips to Lake Tahoe it has been a bit intermittent when it decides to work.
I assumed it was again due to the road salt/debris/water that the electrical connector on the TC shift motor sees.
So i tried to give both sides of the connector a good cleaning once again but no luck it still will not click into 4wd hi or lo and it will not illuminate the dash light for 4wd.
I'm thinking the TC shift motor is toast or at leat the side of the electrical plug w/ the male pins in it so i will replace it asap and will report back.
Anyone else having similar issue???
