4x4 Problem
Old Dec 24, 2009 | 01:18 PM
Brew8's Avatar
4x4 Problem
I have gone through all the usual stuff and here is where I have arrived. The transfer case clutch is working. The vacuum acutator is moving back and forth with the clutch lever. But it will not engage the wheels, they both run free with the drive shaft locked, I lifted one of the ground and turned the other, they are free wheeling. Questions and suggestions appreciated..
Is the diff toast, shift arm bad, not engaging far enough, thanks, Larry
