Tech help. 9"upgrade in 2004 screw
Old Dec 12, 2009 | 01:51 PM
Patrick Shady's Avatar
I'm in the process of installing a 9" rear end in my 2004 screw. Before I took it to the shop i unplugged the sensor on top of the stock rear end and drove it around. It did not seem to affect the truck at all untill I ran WOT and shifing into 2nd gear it stalled and engine light turned on. This is not a speed sensor, speedo still worked. What is this sensor and how can I bypass it when I get the truck back with the 9" rear? Truck is a 5.4. The 9" was installed for an offroad app.
Old Dec 12, 2009 | 08:40 PM
Does anyone atleast know what this sensor is used for?
Old Dec 12, 2009 | 10:19 PM
Read out the OBD2 codes, and that should give you a pretty good clue.
Old Dec 12, 2009 | 10:23 PM
yetti96's Avatar
That should be an ABS sensor I think for the rear end. Why a 9" rear end? I thought the 5.4 always got the 9.75 rear.
Old Dec 12, 2009 | 11:14 PM
Code's Avatar
What you need to retain the ABS sensor is a tone ring. I've seen guys build their own that mount to the x-fer case output or you could run something like in the link below.
The 9" since since it's been used in nearly every motor sport imaginable has a metric **** ton of aftermarket upgrades. You can build the hell out of them. The 9.75...not so much. Best part is if you want to regrear, just buy an already setup 3rd member. I got mine with 5.14 gears and a full spool for 200 bucks, MUCH less than a shop setup would cost for gears alone.
http://www.breaautoelectric.com/products/products1.html
This guy used an 8.8 tone ring
http://www.nloc.net/vbforum/gen-2-li...s-capable.html
Old Dec 12, 2009 | 11:39 PM
My ABS is already disabled. Check my pics before I get harassed for not having ABS. I have a gyphon so I would love to give my DTC but my truck is in the shop.
Old Dec 12, 2009 | 11:40 PM
blubiu's Avatar
speaking of codes does anywon know if ford uses a p-1441 code for the rear diff.
Old Dec 13, 2009 | 12:04 AM
(P2106 - Throttle Actuator Control System - Forced Limited Power. ) I just found this with google and I think this is the code it gave me if I remember correctly.
Old Dec 13, 2009 | 07:35 PM
Still have not figured out what this sensor is for fellas.
Old Dec 13, 2009 | 07:55 PM
Paralyzer's Avatar
why do you want a 9"? the only advatage is fast ratio swaps if you have a few sections with different ratios built. But you have a 4x4 so thats not possible anyways
Old Dec 13, 2009 | 08:08 PM
Why comment if you don't have the answer? It's two wheel drive and a 9" is a lot stronger plus mine is wider.
Old Dec 13, 2009 | 09:48 PM
Paralyzer's Avatar
my bad thought i read 4x4 in there somewhere. Still there is plenty of people runnin over 400rwhp with no problems on a 9.75. The rear sensor is used for ABS and also for calculating load. The truck will not run properly without it and cruise controll will not work either.
Old Dec 13, 2009 | 11:24 PM
Right on thanks a lot. Now I need to find a way to bypass it but I will probably end up having a toner ring made and relocated. My rearend is 6" wider than stock. It has full floating Hubs 35 spline axles and a rear truss. I'm not sure what size gears the 9.75 will allow but I have 5.14, recomended for a 37" tire. All in all it's 100 times better for desert use. It was not worth extending the stock rear end and adding custom hubs to truss over the 9.75 rear cover. Thanks a lot for the info.
Old Dec 14, 2009 | 10:40 AM
minimonster17's Avatar
Just an FYI for everybody, the 5.13 ratio is available for the 9.75 rear... Just not available for the 8.8 IFS front for the 4WD F-150's (It won't fit in the small pumpkin.)
However, I do agree 100% with everything Code said.
Here is a link to a very good 9.75 buildup:
http://www.fourwheeler.com/techartic...ild/index.html
Old Dec 17, 2009 | 04:18 AM
vulsrapet's Avatar
No, it will not strain the tranny...just the performance will suck butt. The tranny doens't know any difference, besides the torque converter locking and unlocking...BTW, is what you're experiencing. It's most likely not dropping in and out of OD.
_________________
Simulation financement auto achat |
Capacite financement automobile occasion |
Calcul taux financement credit automobile
neuve
