Steering help needed
Old Dec 17, 2009 | 07:21 PM
RMCOUTO's Avatar
Unhappy Steering help needed
So I get into my truck tonight and when I turn the wheel to the left it makes a pop/knock noise. It only does it when I turn left and back straight again. Anyone have any ideas on what it might be.????
Old Dec 19, 2009 | 03:27 PM
chiefFX4's Avatar
are you moving or still?
if you are 4wd then check the cvs. if not, might be the rear end.
almost seems like someone needs to make a sticky to remind people in the 97-04 trucks to go ahead and service their rear differential. seems like a lot of posts are popping up with this being the problem.
Old Dec 19, 2009 | 10:52 PM
RMCOUTO's Avatar
It does it when the truck is not moving. I got under it today to take a look and checked the tie rods and the drivers side is nice and tight, but the passenger side has just a little play. I think that might be the problem. Any opinions on this theory??
Old Dec 20, 2009 | 06:23 PM
chiefFX4's Avatar
check your ball joints and the condition of your tie rod ends. might be time for a new idler arm as well.
