Need 97-03 IFS Parts diagram
Just want to see if anyone had a parts diagram for the 97-03 F-150 front axle assembly. Not sure what it is called: Exploded parts view? Illustrated parts breakdown? if anyone has some pics or a link that would be great.
Reason being: My front end started making a thumping sound, and i diagnosed the sound to be the passenger side inner axle was sliding in and out about 1/8", with the axle flange hitting the axle housing assembly. Trying to figure out what i need to replace.
Noise figured out
Well, i pulled out the front axle center section, checked everything and all was in order. diagnosed the problem to a mis-adjusted lower shock mount. seems the shock was rubbing/popping on the lower mount.
Axles kind of made the same sound, but i bounced the suspension with the center section of the front axle out, and found my noise.
***NOTE TO SEL*******Do not consume multiple alcoholic beverages when installing new shocks. Chances are you will miss something.
