front wheel bearing!!!!!
Old Sep 16, 2009 | 11:06 PM
shocar4's Avatar
I have slight play in my front drivers side wheel bearing....is it possible to replace just the bearing or do I have to replace the entire $300 hub????
Old Sep 16, 2009 | 11:12 PM
What year and is it 4x2. Need info
Old Sep 16, 2009 | 11:18 PM
shocar4's Avatar
sorry man! i have a 2003 fx4 screw! thanks
Old Sep 16, 2009 | 11:21 PM
No, don't need the rotor for that one. The bearing can be replaced.
Old Sep 16, 2009 | 11:29 PM
shocar4's Avatar
thanks bluejay....i have been searching, is there a how to on here somewhere?
Old Sep 16, 2009 | 11:37 PM
There is a How To Forum but I don't believe there is one for that application. Take a look. I will do a Search, see if I find anything.
https://www.f150online.com/forums/articles-how-tos-119/
Old Sep 16, 2009 | 11:50 PM
Ok, no luck finding much info. Maybe someone else will chime in.
Old Sep 17, 2009 | 01:17 AM
jbrew's Avatar
On the 4wd , I don't show that procedure, just the entire hub. - Leads me to believe that's what needs to be replaced. PM your email and I'll send you that procedure. Or , just purchase a Haynes or Chilton's book for about 20 bucks.
Old Sep 17, 2009 | 08:56 AM
shocar4's Avatar
well autozone sells the entire hub for $300 (wow) and the bearing for about $20 so I am guessing that you can just replace the bearings....can't believe I am the only one that has wondered about this!
Old Sep 17, 2009 | 10:36 AM
jbrew's Avatar
Yea ,the 2wd is simple - Shows just the bearing and I did a 99 1 ton. That was a simple pack and replace. Let us know what you find on the 4x4. Like I said , I can send you that one from service. The procedure is to long to post here.
Old Sep 17, 2009 | 02:07 PM
shocar4's Avatar
so I called o riellys and I was told that you have to buy the entire hub for the 4x4 application....not what I wanted to hear!
Old Sep 17, 2009 | 03:18 PM
jbrew's Avatar
Yep, it's probably pressed in then.
BTW - I sent you a 3 page PDF from Ford Service for the 03 model year. Open w/Adobe
Thanks to FordTech1.
Old Sep 17, 2009 | 07:58 PM
shocar4's Avatar
thanks man! well I went to o riellys and got the hub assembly and installed it and still have some play.....do i need to replace the wheel seal on the back of the hub where the cv shaft enters? do I need to put any grease at all in there? getting a little flustered with this darn thing!....
Old Sep 17, 2009 | 08:15 PM
jbrew's Avatar
You sure it's not your ball joint ? Or something else ?
Old Sep 17, 2009 | 09:47 PM
shocar4's Avatar
yep....i hold onto the cv joint where it enters the hub on the back side and no movement at all! I just removed the cv shaft from the hub and the seal looks like crap...I am going to get another one and try it again tomorrow! either that or i got a crap hub from o riellys!
