4x4 not engaging at all
Old Aug 21, 2009 | 08:08 PM
Crazy Carl's Avatar
Hi I have a 2002 F150 that has the 4x4 on the floor. Anyways today when i went to put it into 4x4, the shifter was stuck up front and I could not pull it back. I could move it side to side but I could not engage it into 4x4 or 4x4low at all.
I was planning on selling the truck so this is a major defect when selling a large truck like this. So if you guys could help me out with some reasons why this could be happening that what be great.
Thanks,
Carl
Old Aug 22, 2009 | 06:48 AM
corvetteguy's Avatar
My 97 has the same problem.
I put it on the lift and removed the
plastic shroud on the transfer case.
I found a 5 inch vacuum shifter (you may have
an electric shifter) I sprayed lube on parts and
forced it in and out a few times. In one
direction the front wheels lock togeather (good sign).
It is now working again, Maybe I need a new
vacuum part, You may need the shifting motor ($100)
Old Aug 27, 2009 | 10:26 PM
aPINCHbetter90's Avatar
I had the same problem in my 06' but and it was my transfer case, they just replaced it $218.00 wasnt to bad.
Old Aug 28, 2009 | 12:18 PM
kingfish51's Avatar
As you have the MSOF, my guess would be that the linkage is frozen or broke. That would be where I would start.
Old Aug 28, 2009 | 08:24 PM
JMC's Avatar
JMC
25 Year Member
Penetrating oil on the linkage at the joints. I would also spray there the lever enters the T-case. Once you work it free it should shift.
