Traction Control
Old Aug 2, 2009 | 11:20 AM
JScharp 7675's Avatar
Traction Control
I have traction control on my truck but i cant turn it off. Is there a way you can turn it off
Old Aug 2, 2009 | 11:29 AM
BAD DRVR's Avatar
Check your owners manual. It will tell you to push the button to disable it.
Old Aug 2, 2009 | 11:30 AM
BAD DRVR's Avatar
I just thought I would get that out of the way because someone is going to suggest it.
Old Aug 2, 2009 | 01:26 PM
BAD DRVR's Avatar
Hey I was thinkin, I know you have the harness behind the panel with the lighter and back up assist, what if you found a switch at a junk yard or maybe figured out the pin out of the harness and jumper it so its off.
This guy can't power brake, burn outs, or do donuts. The truck retards the engine output like it should but what if you want to have a little fun? And there is no button for the dam thing. I found nothing on the search.
