Differential Wine
Old May 21, 2000 | 07:31 PM
Willie's Avatar
Post Differential Wine
Has anyone experienced a differential wine at 40MPH to 45MPH? If so, what is the probible cause and what corrective action can be taken? 2000 F150,5.4L engine,3.55 ratio regular axle.
Old May 22, 2000 | 04:16 PM
Y2K 7700 4x4's Avatar
Post
Diagnosis involves removing the cover and reviewing the gear wear pattern. Read about it on page 17 of axsm-0043.pdf at http://truck.eaton.com/na/service_pr...nuals/axle.htm -- the axle in your truck is smaller than the ones in my illustration, but the general idea holds water, er wine.
Do you have 4x4? You may not be hearing the axle, but the xfer case or transmission instead.
For some whine the cure is worse than the disease -- in those cases, it's best to devote your attention to wine, than to whine.
Y2K™
XLT SC SB 5.4L E4x4 AW-Disc, 3.73LS, Skid, 7700# HD Towing, Chrome LT-245, Steps, Captain's, 6CD, Tonneau, keyless, Toreador Red, called "Nick"
Old May 23, 2000 | 10:32 AM
Indyfan's Avatar
Post
Willie. While my truck doesn't do it, my wife's Mustang does, when decelerating from between 50-45mph. Ford replaced the ENTIRE rear end (hub to hub) and it's still there. So far they have no other answers.
1999 Lariat Super Cab, S.B. 5.4L, 3.55 LS
and everything but the leaky slider window.
Bright red w/ gold 2-tone, Leather Captain's Chairs
Mods: Duraliner bedliner, Bugflector II, Hide-a-hooks.
& a leeetle chrome tip on the exhaust.
Old May 23, 2000 | 01:43 PM
Jolly_Green_Giant's Avatar
Cool
What do they make differential wine out of? I might like to try it.
If it's differential whine I can't help you.
1998 F150 XLT, extended cab 3 door,Pacific Green, towing package, 4.6L V8, 3.55 LS, Bosh Platinum +4 spark plugs ,Lund deflector, Profile Windstream side window air deflectors, Prostripe silver multistripe, K&N Air Filter, Diamond Plate Toolbox, Diamond Blue(HID) simulator Fog Lights , Whistler Radar Dectector, Uniden Police Scanner, 29WX-ST Cobra CB Radio, with a Texas Star 100watt modulator and a Wilson 2000 Trucker antenna. A Clarion Security System with Keyless Entry,
Audio Mods
Kenwood KDC-6011 CD player/changer control head unit.
JL 10" sub-woofer
Fultron "Depth Charge" amp 200w max.
4, TR570-CX JL Audio Coaxial Speakers (factory location)
Comming VERY soon are a pair of high output headlights (80watt low/ 100watt high)and a K&N FIPK!
Next will be a catback exhaust and a superchip.
Go see my truck and my Grandfather's truck at <A HREF="http://www.geocities.com/Vienna/Strasse/1992" TARGET=_blank>
Http://www.geocities.com/Vienna/Strasse/1992
</A>
Old May 24, 2000 | 05:19 PM
Henry Ellal's Avatar
Post
Willie. I have the same problem. I took it back to the dealer with 7k miles and they said they counldn't recreate the problem. It's noticable around 45-50 mph. I checked the fliud at 14k and it was down 2 quarts. at 16k I removed the cover and checked the gears and they looked fine. Refilled with 75-140 syn and frition modifier and the noise is still there and I changed the fluid in the whole drivetrain at the same time.
99 F-150 XL 4x4. Reg Cab Flareside 4.6 5spd, 3.55LS. gibson 3" cat-back, K&N Gen ll.Westin step bars.Ventshade window deflectors and bug deflector. rhino liner and a cool white shifter ball.
Old May 24, 2000 | 09:13 PM
Willie's Avatar
Wink
Gentlemen: Many thanks for your comments on differential "wine" and differential "whine".
If the differential on my new 2000 Ford F-150, Flareside continues to "whine", I may have to consider "wine" as the corrective action for this problem. Again, many thanks for the help.
Old Jun 9, 2000 | 09:11 AM
Voyageur's Avatar
Lightbulb
Have a similar whine in my '99. Dealer replaced the crown gear and pinion and bearings and then the second time around the entire differential - housing and all. Still there - maybe even a little louder. Very frustrating. They tell me it will never break down but it's still noticable when crusing the strip. Would much like to get rid of it.
Dealer claims that Ford tells him that the gears are square cut and will whine at certain speeds. sounds like a brush off eh!
Old Jun 9, 2000 | 10:12 AM
Willie's Avatar
Post
Voyageur: Thank you for your reply. The Ford dealer tells me differential whine is normal at various speeds. I also have an Expedition with the same differential that does NOT whine. How do you ansewer that? Thanks again for your comments.
2000 F150 4X2 Flareside Supercab Black XLT 5.4L 4SPD Auto O/D Trailer Tow Sliding Rear Window Keyless Entry Sport Cloth Captain's Chairs Power Driver's Seat 6-Disc CD A/C 4-Wheel ABS K&N Air Filter
Old Jun 9, 2000 | 08:46 PM
Stihl's Avatar
Post
Willie, at 6,200 the whine appeared and got worse. They replaced the rear yoke seal once at 5,100. And now the examination revealed it was leaking again....took it in and he said the 3.55 Limited slip is shot! Parts on order to rebuild it and they still need some shims. All this at 6.2K !
99 XLT SC SB 4x4 4.6 Triton
Old Jun 11, 2000 | 04:23 PM
Willie's Avatar
Post
Stihl: Many thanks for your reply on differential whine. Looks like I am experienceing many of the same problems you have had. Good luck!
Old Jun 12, 2000 | 02:00 PM
Jay911's Avatar
Red face
I purchased a '97 F150, 4.6L, used from a non-Ford dealer in April and within 2 weeks realized that there was definitely a whine. It was most prominent when the truck was cold, around 60kph and above, and got louder when making climbing turns (just outside my house is a climbing right turn on an asphalt road). The dealer is currently repairing it, although they haven't given me an idea what they're doing to it.
A co-worker mentioned that his father had an early '97 F150 and had to replace the rear end at 150,000 km and every 150,000 km thereafter. When I started noticing the whine, the truck had about 146,500 km on it.
Not exactly 'happy' to see that this is more than just something happening to me, but I guess I'm more relieved.
Jason
Old Jun 12, 2000 | 02:32 PM
Willie's Avatar
Post
Jay911 Jason: Thanks for the differential whine information. My truck has approximately 3,000 miles on it. I would be happy if the problem did not occur until
150,000 miles! Best regards, Willie
Old Jun 13, 2000 | 08:24 PM
Jay911's Avatar
Post
Got an update: The non-Ford dealer ultimately has sent it to the Ford dealer, who is replacing the diff.
For what it's worth, Willie, this was 150,000 *kilometers*.. which is about 90,000 miles I think.
--jay.
Old Jun 13, 2000 | 09:25 PM
Willie's Avatar
Post
Jason: You are very fortunate that the Ford dealer will replace your differential! I think most dealers feel you should turn the radio up loud to offset the differential whine. Best regards, Willie
Old Jun 14, 2000 | 10:04 PM
Oil Man's Avatar
Post
Check out this rear end cover from Mag-Hytec. It has a lot more oil capicity and seals with an O-ring like aerospace. It has a dipstick and two magnets. It cools about 45 deg F. and looks great. It also adds to the fluid level so as to lubricate the bearings and gears better. This might help the whine. He also recommends the LE gear oils 75w140 synthetic. They have shown lower wear than the Amsoil synthetic 75w90 or the 75w140 by a large amount. This should help you get the maximum amount of gear/bearing life out of your truck. www.mag-hytec.com
or 1-818-786-8325
Sincerely, Kevin
