steady leak
Old Aug 1, 2000 | 01:28 AM
cajunbuck's Avatar
Red face steady leak
i just noticed a steady leak coming from my 94 f150 XLT. i think it's power steering fluid bec it's green (hope that's right). this has never happened before and when i got home i smelled a funny smell and steam was coming out of the hood. looked under the truck and there was a nice sized pool of liquid green on the ground. started her up and a steady stream of green poured out from the truck. i think i have it correctly located, but i am no mechanic and really don't want to put my truck back into the shop. any ideas or comments??!!! Thanks
Old Aug 1, 2000 | 01:37 AM
bubba's Avatar
Post
green would indicate coolant. You might have a leak in the radiator or the water pump. Check your hoses and radiator first then look at the block to see if it is a head gasket.
98 F250 LD 5.4 dual exhaust, K&N, Big tires
Old Aug 1, 2000 | 10:08 AM
wemjr's Avatar
Unhappy
The green color in combination with the steam and puddle on the ground at startup would indicate a coolant leak. More than likely you have a busted hose or a loose connection. Is there any noise at startup? I had a water pump go bad on my car once and it made a squealing noise and eventually busted the hoses. Whatever you do, do not drive it without coolant!
2000 F-150SC 5.4L 4X4ORP
DEEP WEDGEWOOD BLUE
AUTO, 3.55LS, TOW PKG.
CAPTAIN'S CHAIRS,
REMOTE KEYLESS ENTRY
REAR SLIDER
PREMIUM SOUND w/ CD
RHINO LINER
STATE ISSUED UNIV.OF GA. PLATE.
UGA RECEIVER COVER
UGA LICENSE PLATE(FRONT)
WISH LIST:
FLOWMASTER DELTA 40
AIRAID FIPK
SUPERCHIP
TINTED WINDOWS
HOOD DEFLECTOR(PAINTED)
RAIN GUARDS(PAINTED)
A NATIONAL TITLE FOR UGA(FOOTBALL)
Old Aug 1, 2000 | 04:26 PM
gofish's Avatar
Post
Wemjr's right!! Resist the temptation to drive it until you're sure you've got a full coolant system! Tow it if you have to, otherwise, you could freeze up the engine.
If you don't know what you're doing, pay the towing charges play it safe.
