Re-Gearing Question
Old Feb 17, 2009 | 06:12 AM
DOD 4.6's Avatar
Re-Gearing Question
Will these fit an '05 8.8 rear?
http://dagostinoracing.com/index.php...oducts_id=7018
is the 8.8 in an f150 the same as an 8.8 in a mustang?
Old Feb 17, 2009 | 06:38 AM
lew52's Avatar
Do you have a posi unit ...im useing a true trac with 456 gears in 8.8...Yes they will fit ..
Old Feb 17, 2009 | 09:01 AM
yetti96's Avatar
Double check the spline count. It should be either 28 or 31. I know the truck gets 31 and a ranger gets 28 (usually, unless FX4 Level 2) but not sure about mustangs.
Old Feb 17, 2009 | 12:06 PM
lew52's Avatar
The mustang rear is not the same...they have differant axles & differant size axle tubes...but the truck & mustang are both 8.8...so any carrier or gears will fit in both.....If your just doing gears your spline count dosnt mater...only if your going to change the carrier....Your truck should be 31 spline...The mustangs were 28..but most of them went to 31 when they changed carriers ...Lew
Old Feb 19, 2009 | 09:11 AM
brianricks2007's Avatar
I am new to the modification family... I have some BULLITT 3.27 gears for an 8.8
i was wondering if this would work and what kind of difference i should see...
-Brian
Old Feb 19, 2009 | 12:17 PM
lew52's Avatar
First you need to find out what gear you have & how tall your tires are...3.27 gears wont help at all...There is might be a tag on the rear end ??
Old Feb 23, 2009 | 07:38 PM
i meant 3.73 i dunno why i typed 3.27
i've got 3.55
and i'm bout to put some 20" bullitt style wheels with some decent tires around them (don't know exact size yet but don't like the "low-pro" look so they'll be bigger than that)
but i was wondering if those or 3.90 or maybe even 4.11 would be better...
i don't want a drag machine but i want a decently quick truck on the street so which would be better for that???
Old Feb 23, 2009 | 09:30 PM
Fifty150's Avatar
To go from 3.55 to 3.73, you won't see much of a difference. Go up to 4.10. You'll get more power to the wheel, and still have decent mileage.
Old Feb 24, 2009 | 05:06 AM
lew52's Avatar
Depending on how tall the tires are ?? I agree with the 4.10 the 3.73s whouldnt make to much difference..
Old Feb 24, 2009 | 04:53 PM
DOD 4.6's Avatar
i have 275/55R20 tires with 3.73 gears. i'm looking to get better acceleration. should i go with 4.10s or 4.30s? does anyone know approx. what my rpm would be cruising at 70mph with 4.30 or 4.10 with my tire size?
