shaky from stop to 2mph?
Old Jan 22, 2009 | 10:38 AM
fog82mh's Avatar
My 98 F150 4x4 (automatic) ext cab shakes when I start driving...Its only for a second... Its as soon as I start from a stop... also does it when I reverse from a stop...its not all the time but its enough now to concern me...Any Ideas? Any help would be much appreciated...
Old Jan 22, 2009 | 10:48 AM
bigbronc's Avatar
Are you turning at all, or just going straight? This will make a difference in the source of the problem.
Old Jan 22, 2009 | 10:52 AM
fog82mh's Avatar
Good question, I wanna say it happens when Im turning.... although I believe its happened when Im going straight as well... sorry ...this prolly doesn't help haha...Also it seems to be a shake coming from the middle or the rear of the truck...I can't tell for sure though...
Old Jan 22, 2009 | 11:06 AM
bigbronc's Avatar
Sounds like your clutch packs in the posi unit are the culprit. They are binding on slight turns while accelerating. Best way to repair is to replace clutches. You could try adding a bottle of friction modifier to the rear end and see what happens. It is only about $8 from your local dealer. Clutch kit is around $140 plus fluids and labor (about 3.5 hours).
Old Jan 22, 2009 | 11:12 AM
Lumadar's Avatar
Do you have mudders?
Old Jan 22, 2009 | 11:25 AM
fog82mh's Avatar
No mudders on the truck.....I have noticed a shiny spot being worn on the drive shaft right where it meets the transfer case...Is that normal?
Old Jan 22, 2009 | 11:39 AM
bigbronc's Avatar
That's just where the shaft slides in and out of the case during suspension travel. Normal.
Old Jan 22, 2009 | 12:00 PM
sgauthier's Avatar
i'd check the slip joint on the driveshaft in the back of the tranny. might just need to be lubed with a good synthetic grease.
Old Jan 22, 2009 | 12:42 PM
fog82mh's Avatar
cool, thanks guys much appreciated ...I'll look into it... Also at one time I had a ranger with a U joint on the drive shaft that was frezzin up...It made the same kind of shake when I was starting off driving ...do you think it could be something like that?
