grind clunk
Old Nov 26, 2008 | 08:40 AM
dirwood's Avatar
grind clunk
When I go from 2 wd to 4wd at any speed, say over 5 mph, I get a grinding then a clunk. I have no problems if I am stationary or just rolling, it engages perfectly. I tried lubing up the vacuum pod and shaft on the front but it did not seem to help. There also seems to be lots of movement in the fork or is the only wat to diagnose that is to pull the fork right out? It seems to engage to well when not moving to be a vacuum problem.
Old Nov 27, 2008 | 11:03 PM
BigDawg99's Avatar
I am having the same problems as you man..Hopefully someone will come in and answer it..
Old Nov 28, 2008 | 05:38 PM
dirwood's Avatar
Good quote. Hope someone replies too. I posted a reply on the transmiision forum too. Maybe it is a Maritime problem.
Caribou District Fire Department
Old Dec 3, 2008 | 09:08 AM
krusedisc's Avatar
Same problem here. I know that mine engages fine when stopped and eventually engages while moving, but the Bzzzzzzzzzzzzzzzzzz........CLUNK is not what i want to hear.
Old Dec 5, 2008 | 01:22 PM
dirwood's Avatar
Yeah, it really isn't a good sound. I think I have it figured out that it is the electric clutch. I checked at the harness to see if it is getting any power and it is so there must be a problem with the clutch itself. Just hoping to hear from someone who has gone through this problem before.
Old Dec 5, 2008 | 01:46 PM
chris_w_2008's Avatar
im in the same boat. i have manual 4wd no button. but when i engage it into 4wd then put it bak on 2wd the 4wd stays on but its out of 4wd. but i do get that grinding every once in awhile
Old Dec 6, 2008 | 08:07 AM
dirwood's Avatar
I tried to swearch for electromagnetic clutch the other day and it says that I have too many characters in electromagnetic to do the search. I'm going to try another web site to see if I have any better luck.
