Runs faster with new pinion seal
I just got my leaking rear pinion seal replaced the other day. The truck is faster now, acceleration, and holding speed up hills.
My question why would a leaking pinion seal cause the truck to be slower?
The only two things I can figure are.
1) the thick rear end grease is causing friction.
2)the shaft might have been binding up in the seal.
Anyone have any ideas?
Mind you I am not complaining that it is running better.
1999 F150 4x4 4.6V8 regcab/shortbed
Oxford White with Wedgewood Blue two tone, with Blue Captains chairs
Bullet Cat Back, Superchip,WMS Velocity Tube with modified K&N filter.
Centerline Saber rims 17x8" with Firestone GTA 275/60hr-17 tires.
[This message has been edited by Don C (edited 07-19-2000).]
I think it might just be happier; like when you wash it or change the oil.
2000 F-150 XL,RC,LB,5.4,4R70W,3.55LS,
Class III tow/Payload #3/Convenience pkgs.,
4-wheel disc/ABS,Chestnut/Parchment 40/60,
Ford bedliner & gas/wheel/spare locks,
3" cold air box modification,Superchip,
Dynomax ultra-flow welded 3" cat-back.
Look under the hood on the panel above the radiator for a small label. Did the dealer reprogram your computer?
97 F-150, 2WD, Reg Cab,Flareside,Dk Toreador Red, Windsor 4.6, Magnecor 8.5mm wires, Bosch Plat +4s, 3.55 LS, EGR Bug Deflector, ******* Bed Cover, Bed Liner, XL Full Length Running Boards, Air Aid Kit, Gibson Single Out Cat Back, Superchips, TransGo Shift Kit, Hellwig Rear Sway Bar, Hellwig 2500# Overload Springs,Energy Suspension Polyurethane Front Sway Bar Bushings
