2004 FX4 Front Diff and axle shaft leak???
I have a little over 30 k on this truck and was changing the oil yesterday and noticed the right side leaking (almost dripped)So I wiped it off and went for a drive but did not check it when I got home. I looked today and another drop just waiting to fall off. Are there any TSB's out for this? I hate to see what this will cost to fix. It looks to be leaking between the axle assembly and the shaft and joint assembly right between the plates that bolt them together for lack of a better word. Thanks in advance for any help.
Not that much, Probably a Do It Yourself. Jut an Axle seal. Ford could never seal an axle. I had trucks come in with under 10k and have the axle seals leak. I would get bitched at by my boss cause I said something about it cause it was still under factory 10k warranty.
