thoughts on 2-lo setup
Old Jun 29, 2000 | 10:14 PM
BigBunnell's Avatar
Question thoughts on 2-lo setup
I have a 98 f150 with a v-6 5spd 4x4 with a manual transfer case. My question is what are your thoughts on driving in 4lo with the front axle unlocked. I know this can be accomplished by wiring a switch in the wiring between the transfer case and the central axle disconnect. The reason I want to do this is because th reverse on the 5spd is very steep, and makes it difficult to back a trailer up any sort of incline, and i don't want to put any bind on the drive line by being in 4lo on dry pavement. As of right now, this is just in the idea stages and I was wanting to bat it around and get other's ideas.
TIA
BigBunnell
98 F150 4X4 XLT flareside V6 5sp K&N Flowmaster and some other goodies
Old Jun 30, 2000 | 07:49 AM
Granpa's Avatar
Post
Sounds fine. It should help save your clutch in that condition!
Old Jun 30, 2000 | 08:52 AM
Y2K 7700 4x4's Avatar
Post
Very practical for the application you've described. Makes a lot of sense for 'spotting' a trailer in a campground if you need to turn a lot.
Please post the wiring schematic.
Y2K™
Toreador Red, Keyless XLT SC SB 5.4L E4x4 4wDisc/ABS, 3.73LS, Skid, HD 7700# Towing, LT-245's on Chrome, Tube-Steps, Captain's, 6CD, Tonneau, named: "Nick"
Old Jun 30, 2000 | 08:57 AM
Post
Another one that makes as much sense to me is for the xfer case to be able to choose between EITHER the front or rear axle for 2wD -- that way we wouldn't need to drag around 4 bags of sand in the bed every winter.
ARE YOU READING THIS FORD MOTOR COMPANY???
(I hereby claim the patent)
<A HREF="http://www.net-link.net/~n8jg/y2k/mvc-007f.jpg" TARGET=_blank> [img]//www.net-link.net/~n8jg/y2k/mvc-007f_small.jpg[/img] </A>
Y2K™
Old Jul 4, 2000 | 01:05 PM
JMC's Avatar
JMC
25 Year Member
Post
BigBunnell,
I have used that trick in the past. It allows me to use 4x4 so the T-case gets a work out every once and a while. As my truck is still under warranty I just disconnect the electrical connector to the vacuum selonoid. You should have no problems with the front axle. As a precaution always flip the switch before engaging 4x4. This will insure the front axles do not engage when you shift into 4WD.
Regards
Jean Marc Chartier
00 F-150 XLT SC Flairside 4x4 4.6 w/5spd 3.55LSD
Warn XD9000i, skid plates, Draw tite class III,
Rancho RSX Reflex shocks,
Borla Cat Back
Modified Air Cleaner Outlet Tube
and air box, K&N air filter,
Superchips
