Trouble starting
Old Mar 30, 2008 | 02:05 PM
OuTkAsT-F150's Avatar
Trouble starting
What does it mean when I start my truck and it acts like it's coughing or something??? I usually have to crank it 2 or 3 time every time to get it started, new starter maybe? I don't know. Any help would be appreciated.
Old Mar 30, 2008 | 03:26 PM
buckandahalf's Avatar
If you turn the ignition key and the starter turns(cranks) the engine, then disengages properly, the starter has done its job. Having said that, modern gas engines need SPARK, FUEL, COMPRESSION, and TIMING to start, idle, and drive/run properly. This is what I keep in mind when trying to distinguish no start, rough start, driveability compaints. You didn't mention the year of your truck. Is there a check engine light? Is it on? If no check engine light on, codes may be stored that can point you to a specific item on the truck that is measuring(reading) out of range, or not measuring at all. Remember, a code doesn't automaticly mean the part is "bad," it means it needs to be tested.
Now to give it a WILD guess: I would say your problem is likely to be either in the secondary ignition system or the fuel system or a little of both. If its an older truck, I would even check timing just to be certain its right. Good Luck. - B1/2
Old Mar 30, 2008 | 09:24 PM
Thanx man, it's a 97 reg cab and yes the check engine light is on. Gonna find out what's wrong with it this week. Thanks again.
Old Mar 30, 2008 | 10:23 PM
Take it over to Autozone and get a free code readout - and post the exact codes here. They will be a "P" followed by 4 numbers.
Old Apr 1, 2008 | 11:52 AM
f150fella08's Avatar
your idle control motor might be out...happened to me in my old ranger had to crank it about 3 or 4 times b4 it would stay cranked up...idled WAY low tho got a new idle control motor and she cranked right up with no problem
Old Apr 1, 2008 | 05:00 PM
I would not condemn the IAC just yet - need to analyze the codes FIRST.
