Gear Change
Old Jan 20, 2008 | 09:40 PM
johnvirgil's Avatar
Gear Change
I have an 06 F150 with 5.4V8 4WD. My question is about the ring and pinion. I have a leveling kit with 33 inch toyo MT and stock 3.55 ratio. should i change it to 4.10 or leave it the way it is.
Old Jan 21, 2008 | 07:23 PM
electricfrank's Avatar
Just do it
Definately! I changed from 3.55 to 4.10's with the factory 17's on and with the troyer tunes the truck is a blast to drive!!!!
Old Jan 23, 2008 | 11:47 AM
High Profile's Avatar
up to you
depends on how you drive it... you'll have a little more power off the line... the 5.4 is pretty powerful though, so you notice a lack of power in OD @ high speeds? like it down shifting?
Old Jan 23, 2008 | 12:16 PM
black07screw's Avatar
You might want to look at a 4.30 ratio because that will give you about the same set up as the guys with stock tires running 4.10s, just a thought I think thats what im going to do
Old Jan 23, 2008 | 03:49 PM
Jordan not Mike's Avatar
Torque multplication isn't just off the line...with a lower gear ratio, he'll notice more power at all vehicle speeds.
