Anyone have this diff cover?
Old Nov 20, 2007 | 10:30 AM
Psiclone's Avatar
I want to add a new cover to the differential on my truck (2003 XLT FX4). I'd like to get one that has a little added capacity and a drain plug. I found a nice looking one for $85 on ebay, but I'm not sure which differential it's for. I emailed the company, but all they told me was this: The Differential cover part # HZ- 5079 is for stock applications. This cover will fit these 12 bolt applications:
1986-2003 E-250 2WD/4WD.
1986-2003 E-350 2WD/4WD.
1986-2003 F-150 truck 2WD/4WD.
1986-2003 F-250 truck 2WD/4WD.
1986-2003 F-350 truck 2WD/4WD.
1986-2003 Expedition 2WD/4WD.
1986-2003 Excursion 2WD/4WD.
I don't know, so here's the question: Are the covers for the 9.75 and 10.25 the same? Also for anyone that has this cover, does it add any capacity? Here's the link to the auction: http://cgi.ebay.com/ebaymotors/ALUMI...5393QQtcZphoto
Thanks for any help anyone can provide.
Old Nov 20, 2007 | 11:03 AM
Raptor05121's Avatar
I like the one I saw once, it had the F-150 badge smelted into the cover. But then again with all that dirt and stuff under there, why would you want a chrome diff. cover???
Old Nov 20, 2007 | 03:45 PM
Psiclone's Avatar
This one isn't chrome, it's polished aluminum. I'm looking at it because aluminum is a better heatsink than steel is and will do a better job of keeping the fluid cool. I'm not necessarily concerned with the look because of exactly what you said. Loads of dirt and where I live road salt under there.
Old Nov 20, 2007 | 04:56 PM
MercedesTech's Avatar
Go with mag hytech. I went from the stock capacity (like 1, maybe two qts?) to well over 4. Its awesome and is said to run about 50 degrees cooler. It has a magnetic drain plug, a filler hole, a place already done up for a temp guage, and a magnetic dipstick! Yes a dipstick in your diff!! Its sooo sweet! You can check to see if water got in, to check the level... etc!
Also got the mag hytech tranny pan. Went from stock fluid level (16 qts?) to 23 qts!!
Old Nov 20, 2007 | 06:46 PM
street3285's Avatar
Not exactly sure which one mine is, but I do know it is Made in the USA.
I got it from DiffWorks in Corona, CA.
951-549-6780
This is the best picture I have now. I will try and post some later. It is basically a finned aluminum cover with a drain plug and holds more oil and keeps the rear end cooler. Basically just like the mag-hytec, minus the dipstick.
I think both are nice.
