transfer problem
Old Oct 18, 2007 | 10:03 PM
csf150's Avatar
transfer problem
i have 97 f150 with a 5.4 4X4. when i put it in 4h or 4L my front end is not powered. i hear the tansfer shirft when i turn the **** but only my back tires are the only ones what had power going to them. i found this out when i got stuck in sand. any ideas??
Old Nov 7, 2007 | 05:58 PM
johnh002002's Avatar
Me too!
I need to fix mine before winter. Help us both out please.
Old Nov 13, 2007 | 01:08 AM
JMC's Avatar
JMC
25 Year Member
Start by Jacking up the front so the wheels are off the ground. With the truck in park and the engine running engage 4hi. Get under the truck and try turning the front drive shaft. It should not turn. If it does your t-case is not engaged in 4Hi.
The most likely cause is the shift motor. If the front driveshaft doesn't turn the T-case is fine. You will need to check the front axle engagement for problems.
Let me know what is up. I can go farther in the diagnosis but it is 1:08 A.M. so I am off to ZZZZZZZZZZZ.
JMC
