Gears
Gears
Would these gears fit my 05 ford f150 screww 4x4
http://cgi.ebay.com/ebaymotors/ws/eB..._promot_widget
Nope
Your truck with the 5.4 should have the 9.75" rear end. These are 8.8" gears. Additionally this does not say what the gear ratio is that is being sold. What rear end ratio do you have now? Did you know that you need to repplace the front and rear gears at the same time on 4x4? This could cost you upwards of a $1000. It is not a job to be done by a novice mechanic. If your tolerances are off you will lose the rear end.
Funny!
Originally Posted by jiggle
Settle down there, buddy. He didn't say he was doing the work himself. How do you know he has a 5.4L?
I was reading two posts on two different monitors. I must have jumbled someone elses sig with this post. What a tard I can be sometimes.
So what motor do you have CaneCountry89? Will I be proven to have telepathetic powers?
I caught it
Originally Posted by Hash278
It says their 4.10's
Some days............
Well then malexander52's post is correct. Those gears will not work. Only the 4.6L trucks come with 8.8's. Now if you have a 4x4 then you have an 8.8 in the front but it is different. They have what are called reverse gears in the front. You may want to check this out and kind of get an idea at what you are looking at. Just so you know you can not go any lower than 4.56 without having to change the front end. They will not accept anything lower. I would definitely look more into exactly what type of rear end you have.
http://www.precisiongear.com/fordring.htm
Originally Posted by CANES676400
dont people usually go with the 4.56 when the tires are gonna be that big. Is that CaneCountry as in THE U or somethin else cause canes fans are rare in georgia
Originally Posted by dewalt17
Yea 4.56 is what he should get with those tires and if he has a 4x4 like I said earlier that is as low as he can go anyway without getting extra expensive and having to get a different front end.
Then something has changed since I had my gears done because back then I was told nothing lower than 4.56's could be put into that front end. And this was by a Ford mechanic that did my work for me at his home. Would you happen to have a link for where you saw 4.88's for the front 8.8 ifs?
Also when I had my truck regeared I discussed with the shop whether I should go with 4.56s or 4.88s. I went with 4.56s, but they never said anything different had to be done for 4.88s. You could also call Randy's Ring and Pinion. They know everything.
