need help on axle??
Old Aug 18, 2007 | 03:05 PM
BASS ASSASIN's Avatar
need help on axle??
My dad has a 98 F150 ORP with axle code 19.
As far as I can tell this is an 8.8 with 3.55s
We are wanting to upgrade to the 00+ F150 axle with Disc brakes. I keep finding info that the 00+ is a 9.75 axle. I am confused what year the axles were swapped?
all i can find is
19 is 3.55s Non LS
H9 is 3.55s LS
I cant find any info. I hope someone can help me sort this all out! thanks
Old Aug 18, 2007 | 05:29 PM
kingfish51's Avatar
all i can find is
19 is 3.55s Non LS
H9 is 3.55s LS
What engine does her have. If the 4.2 or 4.6, more than likely it is an 8.8. If it is a 5.4, it is a 9.75. Also look at the axle tag. It will have something like 8 8 or 9 75 within the numbers. With a 19 code it is definitely a 3.55 non limited slip.
Old Aug 18, 2007 | 05:45 PM
4.6l
Old Aug 18, 2007 | 06:48 PM
kingfish51's Avatar
Probably an 8.8. Look at the diff cover. If it has 10 bolts, it is an 8.8. If 12, a 9.75.
Old Aug 18, 2007 | 07:10 PM
zabeard's Avatar
if you have the 8.8 is it hard to swap in the 9.75? maybe even the disc brake version?
has any one done this swap?
