Got My 4.10 Installed...sweet!!!
hey guys, I've been reading this post, and it seems everyone is happy with this mod, and forgive my ignorance, but can you tell me what the actual improvements are? I would assume the improvement would be one or two things, or both. Better fuel economy, or better performance, or a cobination of both. I'm mainly looking for better fuel economy, and I have basically a stock 2007 Screw. I am planning on getting an Xcal2 and CAI, but also wanted to look at other mods that would help with fuel economy.
the gears will help alot with low end torq and getting started off the line, the truck will be more responsive and some better towing aswell. As for gas milage it probably wont help much depending on what gears you have now. You will be running at a higher rpm on the freeway with the gears.
A. Lower gears will raise your RPM, relative to how large of a gearing change you make.
B. With same-size tires and a reasonable ratio, MPG may decrease slightly, or remain about the same...while providing more perfromance due to torque multiplication. A large jump may cause a more-noticeable MPG drop of a few percent (or more), as well as greater torque multiplication.
C. If you have super-large tires (35-inches or larger) and stock gearing, re-gearing to a shorter ratio often increases MPG by a few percent (or more) & will restore a lot of your lost power.
D. Typically, a two-step drop in ratio will provide about the same MPG, and significant performance increases, on stock-sized tires. Anything more than a two-step drop will likley cause a drop in MPG...unless you are running larger tires, in which case you may want to consider more than a two-step ratio drop in ratio (see C, above)
If you are just looking for MPG, aren't looking for performance, and are running stock tires, then re-gearing may not be for you.
I put 275/55/20 (31.9") tires and wheels on my truck, and compared to stock the truck is just gutless. I have an '06 with a 4.2, 3.55 gears and a 5 speed manual. I used to be able to chirp the tires into second without trying, and now I can barely chirp the tires in first when trying. My mpg dropped around town but I guess it might have helped on the flat highway, but I don't drive on the highway, and I mostly drive on rural 55mph roads or 45mph city streets. Im going with a 4.10 to get back my power and city mpg, and the only time Im on the freeway is when Im going up the mountains .
The best gear ratio depends on how you drive, where you drive, what you want, and tire size.
Originally Posted by Jordan not Mike
What size tires on those 20s?
'06STX,
I don't think you're going to notice a difference in highway MPG.
I didn't - went from 3.31 to 4.10, on 285/60-18 tires (about the same diameter as yours).
Most other folks don't report any change in MPG, either, when they go to 4.10s on stock-ish sized tires.
