regearing with 35's
Old Jun 26, 2007 | 12:31 AM
fordman164's Avatar
regearing with 35's
i want to regear my truck because im getting some 35's. my question is whAT gear ratio should i go with. i want low end torque for wheelin but i still need to go on the freeway. is any one running between 4.10's and 4.58's. on there truck with 35's. thanks for the help in advanced
Old Jun 26, 2007 | 12:43 AM
infinityphotog's Avatar
Hey,
I'm looking to do the same, 35's suck with stock gearing. I'm on an 01 4x4 Screw. If you find some legit pricing and what not, PM me please!
Thanks!
Old Jun 26, 2007 | 10:15 AM
Hash278's Avatar
Go with 4.56's with your 35's that should bring you about back to stock.
Old Jun 26, 2007 | 10:28 AM
bigtruck311's Avatar
4.56
Old Jun 26, 2007 | 03:02 PM
fordman164's Avatar
Originally Posted by bigtruck311
4.56
so if a 4.56 will bring youback to stock than what would give me a little more torque but still freeway drivable
Old Jun 26, 2007 | 03:47 PM
acm8705's Avatar
If your stock ratio is 3.55, 4.10 will put you back to stock.
If your stock ratio is 3.73, 4.30-4.56 will be back to stock.
I have 4.56 with 35" tires and love it. Should've done it at the same time I got the tires. I get a consistent 14 -15 mpg no matter how I drive.
Old Jun 26, 2007 | 06:28 PM
Cuisi's Avatar
See for yourself;
http://www.accuautoparts.com/calculatorfin.jsp
Old Jun 28, 2007 | 01:05 PM
KYLE RYAN's Avatar
A 4.56 Is As Low As I Would Go. If You Do Much Interstate Driving You Probably Should Look At Some 4.10 Or 4.30. I Put 4.56 In My Truck With A 33" Tire And It Runs About 2800 Rpm's At About 75.
Old Jun 28, 2007 | 02:18 PM
fordman164's Avatar
all i really drive is backroads and occasional freeway
Old Jun 28, 2007 | 05:14 PM
4.56 will get you what you want with 35"
Old Jun 29, 2007 | 12:26 AM
fordman164's Avatar
great thanks for all the imput. i got a quote today
for 700 bucks per axle. is that good
Old Jun 29, 2007 | 11:52 AM
with parts or for labor only?
Old Jun 29, 2007 | 02:40 PM
BJN708's Avatar
I hope that $700 includes a nice setup up of gears!
I payed $250 per axle for labor, and about $500 for Yukon gears and Master Overhaul Bearing Kits for both axles. You should be able to only spend just a little over $1k.
I also went with 4.10s. Good mpg, but I regret not getting 4.56s.
Old Jul 1, 2007 | 01:57 AM
fordman164's Avatar
it was for parts and labor per axle.. is that good?
