4x4 Question
Old Mar 1, 2007 | 09:10 PM
Flan's Avatar
4x4 Question
Ok so I got a 2002 Supercrew, My dad told me its not good to go over 40mph when in four wheel drive, can some one confirm this? also when I put it in 4x4 and make a hard turn it starts to jerk like hell, and when there is no gas applied it will just stop when turning, but im pretty sure this is because there is no front differential. Could someone please also confirm this for me please.
Old Mar 1, 2007 | 09:17 PM
firedognick's Avatar
fords manual says that you can travel no faster than 70mph in 4x4hi. As for the turning I dont know but mine does the same thing so I usually just put it in 2x4 if I am turning tight corners and such.
Old Mar 2, 2007 | 05:06 PM
GIJoeCam's Avatar
According to the owner's manual, it should be engaged at speeds of no more than 55 (45 when below freezing) but once engaged, drive it as fast as you wish.
As for the binding when turning, that's called driveline bind-up, and it's very bad. If you experience driveline bind-up, you shouldn't be in 4wd anyways as you are likely on a high-traction surface. Your front differential is working just fine.
-Joe
Old Mar 7, 2007 | 06:21 PM
buckdropper's Avatar
From: south western NYS Latitude: 42.34 N, Longitude: 78.46 W
-Joe
Very well said..
