My axle is 3:55 TL does this stand for traction lock? My axle code is 19 if this helps? If so is that the same as LS limited slip?? confused? Also would the front be the same?
WHERE are you seeing this??? TL would be an abbreviation of TractionLok; the name of the Eaton limited slip that Ford uses. Check the axle tag. Maybe it got swapped.
