Rear Diff. Filler Plug.
Old Dec 7, 2006 | 05:57 PM
boomerssc's Avatar
I just replaced my pinion shaft in the rear and now i am trying to fill the fluid, but the plug is in there tight, so tight it the plug stripped out. I drilled it and tried to use a bolt extractor but it broke the T-handle clear in half. Any Suggestions. It would really be appreciated.
Old Dec 7, 2006 | 06:26 PM
F151's Avatar
PB Blaster. But it may be too late for that now. Pull the cover.
Old Dec 7, 2006 | 06:36 PM
boomerssc's Avatar
Tried that before I drilled it, pulled everything off and still nothing, I am thinking about taking a chisle to it, as last resort, that is.
Old Dec 8, 2006 | 08:56 AM
GIJoeCam's Avatar
Heat the area of the casting around the plug with a propane torch, then use the extractor. The factory uses a thread locker/sealant that requires heat to melt it. You don't need to make it cherry-red, just a little warm.
-Joe
