nasty clunk in 4x4
Old Oct 25, 2006 | 12:36 PM
garbonzo's Avatar
nasty clunk in 4x4
I have a 1999 f150 4x4 automatic,when in 4x4 there is a bad clunk ,i suspect its in the transfer case or front dif but not sure,please can someone help
Old Oct 25, 2006 | 07:14 PM
The Saint's Avatar
Do you have oil in the transfer case?
If yes, when was the last time you changed it?
I think I recall an issue with greasing the rear drive shaft slip yoke on the earlier 4x4's.
Old Oct 25, 2006 | 09:00 PM
BLUE20004X4's Avatar
Depending on the noise I guess, there should be somewhat of a clunk, especially in 4l, clunks like hell.
Old Oct 26, 2006 | 03:20 AM
JMC's Avatar
JMC
25 Year Member
Does it clunk only once when engaging 4x4 or does it do it all the time? Electric or Manual Shift on the fly t-case?
JMC
Old Oct 26, 2006 | 06:18 PM
garbonzo's Avatar
Its AN ELECTRONIC SHIFT AND IT CLUNKS HARD WHEN YOU ARE PUTTING ANY LOAD ON THE 4X4
Old Nov 2, 2006 | 07:42 PM
TXallstar's Avatar
i have the electric shift and it does clunk a little bit when engaging but that is normal. They can be a little fussy at times but it shouldn't be that bad. I would have it checked out by a mechanic.
Old Nov 3, 2006 | 08:57 AM
JMC's Avatar
JMC
25 Year Member
Do the 4x4 indicator lights come on in 4 wheel drive? Does it clunk in both 4Hi and 4Lo?
JMC
