Noise in rear-end? Help!!!
I need some help! I just finished putting on some 3" Bullseye Wheel Spindles on my 99 F-150 4X2 and a 3" Block and U-Bolt Kit in the rear end. After installing it I know have a noise coming from the rear end. When I come to a stop and when I let off the brake and hit the gas I hear a thump in the rear end. I don't know what it is and I hope someone can give some advise!
Set your parking brake and give some torque to the axle in both forward and reverse. Have someone look at the axle wind-up to see if the axle is rocking on the springs.
Watch for movement at the front spring anchor bolts to ensure that those bolts are not moving.
Watch for movement of the driveshaft to see if it is not binding while trying to move fore and aft.
If you cannot find anything right away, drive it for some time and look for any telltale 'fretting' -- the motion of two parts -- which shows up over time as a rusty powder at the point of the fretting. Most people disregard that telltale rusty stuff as just rust and not evidence of movement.
If all else fails, add a sub-woofer to your sound system and just boogie on...
Y2K™
XLT SC SB 5.4L 3.73LS
Y2K™
ha ha. I just posted the same topic in suspensions....any solutions to our problems anybody......Thanks in advance...Dave
[IMG]//albums.photopoint.com/j/Thumbnail?u=688963&a=5018235&p=19970291&Width=100& Height=100&Sequence=0[/IMG]
1998 F-150, SC/Flairside,oxford white 4x2,4.6,auto,3.55s,nerf bars,cls 111 towing,bed liner w/mat,atlas polished wheels w/285/75 R/16 BFG A/Ts (black side out),all plastics guards/bug shields,air raid/k & n filter, superchipped, duals out the back corners, flow master 3 chamber, snug top lid, f-150 online sticker back window-honk if you see me!!! Fabtech 3 1/2 lift .coverking dash cover, Lumi Logo's (front and rear), clear front corner lenses, muth mirrors,3" bullseye spindles, dash mounted CB, (TX Chapter requirement,lol),personalized license plates.
San Antonio
DWESSELS89@AOL.COM
San Antonio
DWESSELS89@AOL.COM
