idle hum
Old Mar 31, 2000 | 01:46 PM
Raoul's Avatar
Certified Goat Breeder
25 Year Member
Post idle hum
I didn't post this under the rough idle/vibration threads because it seems different from the symptoms described there. This hum only occurs when stopped with the truck in gear and the brake applied. If I shift into Neutral the hum stops. I have tried to find where it's coming from. I applied the E-brake put the truck in gear and checked all around it. The only places I hear the hum are in the cab and right at the front of the bed where it meets the cab. I can't hear it from underneath the truck or under the hood.
I do 'feel' it in the gas pedal.
I think it must be drivetrain related because the noise stops when in Neutral.
(Just because I give everybody a hard time, I know you guys won't hold that against me.)
If somebody don't solve this for me, I'm going to buy a Chevy !
The Bank ain't going to like if I tell them their $25,000 truck has a flaw!
99 Lariat Normal Cab 2WD 120"WB 5.4 3.55LS, Tow,
Dark Toreador Red/Harvest Gold, Line-X
raoul_oba@hotmail.com
F150's of Virginia
Just cause we're from Virginia don't mean we're(well, you know)
Old Mar 31, 2000 | 10:00 PM
stephen muscio's Avatar
Post
Raoul, I have a 4.6 and it has a humming sound when in drive and the brakes applied also. I thought it was normal, now I'm all upset cause if you got it must be bad. I will check it out on my way to the local Chevy dealer tommorow, there just giving those Siverado's away. I'll let you know what I find.
Old Apr 3, 2000 | 09:59 PM
Y2K 7700 4x4's Avatar
Wink
The humming is not so bad.
It's when they start Singing, that make me crazy.
Old Apr 5, 2000 | 01:29 AM
Post
Raoul, I checked the idle hum on my truck today. At normal operating temp idleing and in drive it has low pitch hum. In neutral it stops. I did not check outside of the cab.
Old Apr 5, 2000 | 01:08 PM
bazil1's Avatar
Smile
*Mine* hums 'cause it doesnt know the words!
Actually i do have an intermittent hum in it and its been around ever since I took out the silencer which is located between the airbox and the throttle body. There is a slight air leak in the tube. I know what it is and I live with it. When i step on the gas it goes away...and when I feather the throttle it also goes away.
Maybe we can get a F-150 online Site discount buying Chevies.
'97 S/C XLS black/silver 157" WB, 4.6/auto, 3:08, home made custom stainless tube grille, terminator muffler, phantom sweep wiper switch(factory installed), a few billet aluminum goodies (the list grows), airbox mods, TPS tuned
email: bazils@hotmail.com
http://content.communities.msn.com/bazilspix/PhotoAlbum
Old Apr 16, 2000 | 11:23 AM
roadrunner's Avatar
Cool
Hey Raoul - I know why a bee hums, cause it's got his "honey" between his legs !!!!
I DON"T know why the tranny hums - mine does exactly the same thing as yours.
SOMEONE on this board must have a clue.
Until your post - I thought I was the only one !!!
98 F150 S/C 4.6 2wd Vermillion/Silver,HD Tow Pkg, Boards, Vents, Lund Bug Chaser, LaBra Tonneau cover, DIY "breezer" Tailgate, 5th whl hitch, Tool box, 16" OEM Mag's,BEEP,BEEP roadrunner floor mats.
Mobil1 /Wix Oil filter/ K&N / air box mod.
In looks & go - Chevy - like a rock.
