softer clutch
Old May 29, 2006 | 01:47 PM
jstaf40's Avatar
softer clutch
hope u can help i have a back injury and it is hard to depress the clutch for extended time, is ther a stronger master cylinder or slave that would make it easyer to clutch i have a 98 f150 6 5spd stx
thank
john
Old Jun 7, 2006 | 11:22 AM
GIJoeCam's Avatar
Nope.... Time for an automatic. Sorry.
-Joe
Old Jun 11, 2006 | 03:11 PM
ajbuick's Avatar
When Was The Last Time You Inspected Your Clutch And Pressure Plate, I Had The Exact Same Problem, The Clutch Was Extremely Stiff And Very Hard To Depress, I Tried Bleeding The Slave And Even Had It Replaced. When I Pulled The Trans To Do The Clutch I Noticed That There Where 2 Broken Springs On The Pressure Plate. The New Clutch AND PRESSURE PLATE I Installed Was A Heavy Duty Unit Yet The Clutch Is 100% Easier To Depress. I Also Changed The Pilot And Throwout Bearing
