Ring and pinion
Old Feb 13, 2006 | 11:19 PM
markclement's Avatar
Ring and pinion
Hi
I have a very important question. I have a 97 F250 H/D witha a 460 gas motor. The truck came with 3.55 greas. It also came with (after a metric to domestic calc) about 30" tires. After a long story and changing the tires 3 times I ended up with 35" tires. I pull a 33' trailer and don't seam to have as much low end tourqe. After some reserch I came up with having to change the dif grears to about 4.10 gears just to get back to factory low end tourqe.
Like I said I did some research to get here. Now I speak to a freind in a tranny shop and he started laughing and said I ws crazy. He said I should go with a custome converter. Now I am the one confused. I felt it was simple math and that if you change the tire diamiter you new to change the gear ratio to make the correction. Anythoughs?
Old Feb 14, 2006 | 09:49 AM
jhoparmy's Avatar
You are correct. If your running 35" tires you need to change your gearing to 4.56's. If you do a lot of towing you might even consider 4.88's since the 35's are a lot heavier than the stock tires and you would notice a big improvement on take-off. Hope this helps.
Old Feb 14, 2006 | 01:47 PM
max mitchell's Avatar
Run from the laughing torque converter guy! Changing your tires would be alot cheaper on a 4X4. Changing the gears would be the normal procedure if you're fixed on a certain tire height. You should plug a few figures into a gear calculator to find a desirable choice.
http://www.ring-pinion.com/content/calculators/RPM.asp
Old Feb 15, 2006 | 06:54 PM
Thanks very much for your help. It makes sense. You guys are great.
