What is a "4x4 motor"?
Old Dec 16, 2005 | 07:05 AM
Sarnan's Avatar
Ford dealer said I needed a new "4x4 motor" to solve a grinding noise in the transfer case. Does anyone know what the "motor" is or does?
Old Dec 16, 2005 | 10:46 AM
MitchF150's Avatar
It's what shifts the TC so the front drive shaft gets power. Instead of a lever to do it, you have a switch on the dash and this motor does the work for you.
The dealer is not selling you a "muffler bearing", so take them for their word and have them fix it if that's the route you want to take....
Good luck!
Mitch
Old Dec 16, 2005 | 04:01 PM
Sarnan's Avatar
Thanks Mitch.... Is motor vacuum controlled? Located under the dash or at the TC? It's been grinding intermitently for a while. I thought it was a solenoid.
Old Dec 16, 2005 | 06:28 PM
MitchF150's Avatar
As far as I know it's electric and it's mounted on the TC. Looks kinda like a mini starter motor. I'm not positive, but I think the low range selector is a separate one, and that might be what you see when you are looking at it from underneath??
Sorry I can't be any real help on it...... I just know it has a motor to engage 4wd and/or low range.
Mitch
Old Dec 16, 2005 | 10:52 PM
fordninja's Avatar
It is an electric motor located on the t/c. It controls any shifting of the transfer case, ie 2wd to hi to low.
