Rear axle oil
Rear axle oil
All,
I have a '03 FX-4 F-150. At what mileage do I need to change the rear end oil? What type of rear end oil do I need to use ( I would rather go with Ford Motorcraft brand)? I am almost sure the truck is limited slip. Also I have noticed when I turn sharp @ take off I can feel a viberation in the rear end like the tires are wanting to break loose. Is this normal for this truck? THANKS for any info...............
on
Haynes sucks. Ford says officially you aren't supposed to service it unless the fluid gets contaminated, like with water when launching or retrieving a boat. But if you really want to, I'd go every 100K or so, maybe 60K if you beat on it real hard, like smashing around offroad a lot or something.
