No 4X4
Old Sep 13, 2005 | 04:06 PM
Schwerm's Avatar
No 4X4
My 4X4 isn't working. The problem originally started by shifting into 4x4 intermittently, then if left in 4X4 position overnight it would engage when started up in the morning, now nothing. I have the 4.6 w/ manual shift. I'm getting 12v to vacuum solenoids @ the pass. side firewall, 8.5v to the switch on transfer case, linkage does engage the front driveshaft, diff lock vacuum motor stays @ unlock w/ vacuum holding it there. If when shut off I place the diff vacuum motor in lock position, it goes to unlock @ startup. It seems that the vacuum solenoids are not being energized properly, any ideas what may be causing this.
TIA
Dan
