Grinding noise from Transfer case?
My 05' F 150 has been in and out of the shop for a intermitant whining or grinding sound that sounds like it is coming from the front of the vehicle area. They are unable to find or reproduce the sound at the dealership. The reason I think it is the transfer case, while the sound was happening, I reached over and flip on the 4H and the sound went away. Any ideas on what it might be?
Fixed? I Hope...
They replaced the faulty 4 X 4 vacuum control solenoid. Here is what was on the invoice:
Verified concern WDS; No codes. Pinpont test SSM and TSBS; Removed and replaced part of front Trans Diff shaft collar for 4 wheel drive, checks ok. Trace vacuum coming on while not being commanded. Pinpoint faulty vacuum control solenoid. Replaced solenoid. Removed and replaced both outer hubs, pulled apart vacuum hubs at wheels. Removed and replaced halfshaft. Removed and replaced rotors and calipers. Road tested, checks ok.
It looks like they replaced hubs assemblies a vacuum switch nd R & R 'd the calipers and rotors for any damage.
Hope this fixes it...
