Front Left Click?
Old Aug 17, 2005 | 02:29 PM
dnale's Avatar
Question Front Left Click?
Last winter I replaced most of the front end parts of my '99 S'Cab 4wd. Inner and outter tie-rod ends, upper and lower ball joints on both sides. Lately (for about the last month or so) I have a popping sound coming from the left front somewhere when I put in and out of my driveway and garage. I've checked ball joints and tie rod ends and they all look and feel good. Now when I drive slowly (like under 35) I can actually feel a clicking in the steering wheel and hear it come from the left side. Is this a wheel bearing? I just had it in for tires today and they did an alignment and they confirmed ball joints and ends were good (which they almost always say are bad...)
I thought the popping might be from a loose bolt on the front left shock but it's tight too, plus I don't know how that would make the clicking....
Any ideas?
Old Aug 17, 2005 | 02:39 PM
rkjerue's Avatar
Hello dnale,
I have a 2000 4x4, at about 75K miles I started having a similar problem it, it was one of the front axle's binding. I could reproduce it by coming to a complete stop tuning the steering wheel all the way form left to right then pulling forward very slowly maybe 1/2 foot to a foot and one front axle would pop, you could put your hand on the hub cap and feel it push out during the pop sound. I had the axle replaced with a re-manufactured one and the problem was solved.
Old Aug 17, 2005 | 02:43 PM
BBMFB's Avatar
I had the same noise coming from mine. turned out it was the lug nuts had come loose just enough for them to rattle.
Old Aug 17, 2005 | 03:43 PM
dnale's Avatar
I've got about 175,000 on it, and it hasn't been an easy life for it, but I have no thoughts of stopping to drive it.
I am sure it's not a lugnut loose. I've pulled that wheel several times and it always comes back. I used a torque wrench set at 100ftlb's and its still there.
An entire front axle? Just 1/2? or the entire assembly?
Old Aug 17, 2005 | 04:40 PM
rkjerue's Avatar
Just the half shaft on one side.
Old Aug 17, 2005 | 04:53 PM
dnale's Avatar
Does it take any more than just the 1/2 shaft? New bearings? CV joint?
Old Aug 17, 2005 | 06:19 PM
rkjerue's Avatar
I took it to a shop and had it done, so I am not sure of the details of the install but everything costs about $225.
Old Aug 17, 2005 | 09:31 PM
dnale's Avatar
Does anyone else know whats involved in this? How do I check to see if the half-shaft is shot?
What if it is and I keep driving? What are the downsides?
Old Aug 25, 2005 | 12:06 PM
dnale's Avatar
Unhappy
I thought I had this noise figured out. I replaced the lower shock mount bolt and nut with ones that I could get wrenched on and it was gone for a day... Or at least I didn't notice it for a day. I haven't had the chance to see if the new bolt is loose but it didn't "look" loose and I couldn't remember what the torque spec was on it. I replaced it with 1/2" Grade 8 hardware so it shouldn't be a strength problem.
