differential tag
Old Jul 22, 2005 | 02:57 AM
bigben2005's Avatar
differential tag
the tag on my differential says S828A 55 88 9H06, what does this mean? do i have LS?
Old Jul 22, 2005 | 01:49 PM
GIJoeCam's Avatar
First part is the plant code:
S828A
Second part is the axle ratio: There should be a "3L" preceding the 55 if it's a Limited Slip. If it's open, it should just say '355' I believe.
4th is the ring gear diameter, in your case an 8.8 inch.
5,6,and 7 are the build year, month, and day, in your case, August 6th, of '99. (9=1999, H=8th month [and there is no 'I' in the sequence]) and '06' is the 6th.
Too much info..... Need to know either what precedes the '55' or what the axle code is on the sticker inside the driver's door.
-Joe
Old Jul 23, 2005 | 12:53 AM
bigben2005's Avatar
there is nothing else by the 55. but my axle code is 19. what does that mean?
Old Jul 23, 2005 | 05:50 AM
BLK1's Avatar
19 = 3.55 Non-LS
