is an '03 rear different from a '97?
If they are both the same diff, 8.8 or 9.75 then you can swap them. The 8.8 came with the 4.2 and the 4.6. The 9.75 came with the 5.4. I would not swap a 9.75 for an 8.8 but the other way would be fine. If you do swap different sizes, then you will have to change drive shafts probably.
