Noisy LSD
Noisy LSD
No, this is not about bad drugs. The 3.73 Limited Slip Diff. in my 2004 5.4L XLT 4x4 shudders and groans in low speed turns. Part of me says that this is normal for LSDs and this is how you know it's working. Then I heard that Ford issued a TSB in June 2004 on this issue. Anyone know what it said? Anybody else putting up with this "problem"?
I recently had a Ford LSD uit installed. After a few hundred miles, it started doing this.
After I had the fluid changed and added the friction modifier, it completely went away.
When was the last time you changed the fluid & added friction modifier?
Good news. The dealer just called and they are going to change out the clutch pack. Originally he said that Ford was working on another fix, but I guess that's still a ways off.
