how to change to a limited slip rearend
I have a 1997 f-150 4.2, 2 wd and i was wondering if it is worth the time and money to install a limited slip rear end, and what kind of money and time would i expext to pay, or can i do it myself????
It becomes more worthwhile if you change gear ratios at the same time. Cost should be around $700 and more like a grand with gears. You can also junkyard shop for entire rear ends.
Here's how it's done:
www.ring-pinion.com/tech/yukoninst.pdf
