4wd
Old Oct 5, 2004 | 10:00 AM
cowboycp's Avatar
4wd
i looked at my rear axel pumpkin and i have two tags hanging of of it so that means i have power going to both of my back tires i think. So how do i get power to both of my front tires at the same time. I was trying to pull an old international rig out of a hole and i could not get my front tires to pull, just my back tires were spining. is there any way to make all of my tires pull at one time?
Old Oct 5, 2004 | 01:52 PM
F150Flare's Avatar
I believe in order to have power to both of your front tires in 4wd all the time is to install a set of lockers.
Old Oct 5, 2004 | 04:37 PM
bigtruck311's Avatar
you will need to get a selectable locker for the front axle, auburn gear makes the ected(electric) eaton makes the e-locker(electric) and arb makes there locker (air) this site has them all www.4wheelparts.com
Old Oct 5, 2004 | 05:58 PM
kingfish51's Avatar
If only your back tires are spinning, and not at least one of your fronts, you have some kind of problem with your 4x4 system.
Old Oct 7, 2004 | 11:11 AM
Dad's Hoss's Avatar
I think Kingfish is right, if your in 4x4 mode, you should have one of the front tires turning.
Old Oct 7, 2004 | 01:33 PM
yes one of your front tires should spin in 4x4
