Axle ratio change question
Old 08-21-2003, 12:49 PM
Enigma66's Avatar
2000 Expedition 4wd 3.55 limited slip
Truck came stock with 255/70 R 16
I want to go up to 265/70 R 17
That change of tire makes the "real" rear axle ratio 3.38
Will this hurt or help my MPG?
I know this will negatively effect my towing ability. How much will this change affect pulling a 5000 pound trailer through mountain pass type conditions?
Old 08-21-2003, 01:17 PM
flafonman's Avatar
The max trailer weight for a 3.31 rear gear is generally about 1000# less than a 3.55. Check your owner's manual for details specific to your vehicle.
To cut through to the heart of your question-"Will you notice the difference?
MPG will probably go up a little.
Towing performance will be reduced.
Old 08-21-2003, 02:13 PM
SVTErick's Avatar
go with 4.10's!
Old 08-21-2003, 02:18 PM
flafonman's Avatar
Originally posted by SVTErick
go with 4.10's!
You should consider putting that as your sig.
Congratulations on becoming a Senior Member BTW.
Quick Reply: Axle ratio change question
