Gear Lube
Old Dec 27, 1999 | 08:12 PM
Bent6's Avatar
25 Year Member
Post Gear Lube
Because of my trucks high mileage and a leaky pinion seal, I changed the lube in the rear diff. I used synthetic 80-90W. Afterwards I found out that 75-140W synthetic was recommended. No one carries that weight of lube in quarts (though I found a 5 gallon bucket for $137). So, I called the dealer. I was shocked by the price. It was over $20 a quart (3 required)! I don't pull to much heavy stuff so I'll wait a while to change to the heavier lube.
97 XLT S/C Long Bed 2wd, 4.6 Romeo, 4R70W Trans., 3.55 LS, 181,000 miles
Old Dec 27, 1999 | 08:45 PM
msparks's Avatar
Post
I can get it to you for $8.95 a quart + shipping.
Email me if you want some.
or check out my web site under products!
Lube-Direct
[This message has been edited by msparks (edited 12-27-1999).]
Old Dec 27, 1999 | 11:28 PM
Bent6's Avatar
25 Year Member
Post
Is that price for TGO-QT - Series 2000 SAE 75W-140 Synthetic Gear Lube?
Old Dec 28, 1999 | 11:08 AM
GreenHornet's Avatar
Post
Bent6, I had done that to a couple of customer trucks with the Mobil 1 gear lube 80-90W and I had to end up paying dearly for it. It will turn the gears "yellow" and is not compatible at all and down the road will harm the gears. I had personally spoke to Mobil, Castrol, Penzoil and Texaco petroleum technicians about this situation and they all agree it is harmful to these new Ford rear ends, because the customers was hearing slight moans about one month after.
I had to ended up flushing out the axle and refilled with the 75-140 and let it run for 2 days and drain it out and refill again. This stopped the customers from filing a lawsuit and now I'm responsible for the axle problems if any comes up. Drain it as soon as possible and refill with the proper weight synthetic oil now.
Old Dec 29, 1999 | 10:36 AM
msparks's Avatar
Post
Sorry, I looked at the wrong price.
The Series 2000 75w140 is $11.95 a quart. This it 100% synthetic. Still better than $20.
Lube-Direct
Old Dec 30, 1999 | 02:26 AM
Neal's Avatar
Cool
HI!... BENT 6 : When I had my 4.10 gears installed at my dealer I had them fill up my rearend with REDLINE synthetic gear oil. (PART # 58204) 4 liters cost me $59.57(CAN). I have had my gears and oil in now for about 5 months now with no problems or whining whats so ever. The mechanic that installed my gears even told me that I was smart to use REDLINE oil because it is the best. He also told me he used it in his truck as well.
NEAL [ the horsepower freak ] NEWMAN
'99' F-150 XLT SPORT, oxford white, reg cab shortbox stepside,5.4, auto, 4.10L.S, captain's chairs, bedliner, GTS carbon fiber headlight covers, **** CEPECK clear halogen driving lights, GTS slotted tailight covers (painted oxford white), FORD locking lug nuts, tinted windows,true duel exhaust with 2.5 inch mandrel bent pipes and FLOWMASTER 3 chamber mufflers with 3' tailpipes exiting before the rear wheel like the LIGHTNING, HELLWIG rear stabalizer bar, AUTOMETER guage pod and tranny temp guage, custom fabricated air intake trac and huge K/N filter, TPS mod, BELLTECH 2-inch rear drop, custom programed SUPERCHIP.
FUTURE MODS : JBA headers, power pulleys, twin electric fans, traction bars, BAUMANN ENGINEERING shift kit, and a KENNE BELL BLOWZILLA supercharger.
ESTIMATED H.P TO DATE : 310H.P / 405ft/lbs of torque.
OTHER TOYS : "83" PRO STREET FORD RANGER : 351-w 530H.P(natural), 750H.P with N.O.S, tubbed (crome moly tubing), 12 point chrome moly roll cage, 4-link with coil overs, MUSTANG II front suspension, c-4 tranny (race prepped), 4000rpm stall converter(8 INCH), 3" chrome moly driveshaft,AUTOMETER guages, 15.50 MICKEY THOMPSON rear tires, 4" M/T front tires, fiberglass hood - bumper - prostock hood scoop, wishbone trac-link, two chrome moly driveshaft loops, 16 gallon RCI fuel cell,etc
[This message has been edited by Neal (edited 12-30-1999).]
Old Dec 30, 1999 | 04:27 PM
BigDaddy's Avatar
Cool
Bent6 -
Ditto on the Redline - I just replaced my Diff Cover and filled it up with Redline 75-140. Price was $7.95/Qt from Summit Racing. Prior to this, I had bought some of that Mobil 80-90 stuff at AutoZone. When I arrived home and realized it was not the correct weight - I ordered the Redline.
-BigDaddy
97 Lariat SC, 4.6, CD, TT package.
Plus: Superchip, Borla, AirAid, Leather Steering Wheel, Trick Flow Diff Cover, BossLock tailgate Lock.
Old Jan 2, 2000 | 06:47 PM
WhiteStallion's Avatar
Post
This is interesting because I am looking at the owners manual and it has a Ford part# of XY-80W90-QL for the diff lube.
97 F150 XLT SuperCab 4.6L 2WD White w/red and blue custom pen striping.
Old Jan 13, 2000 | 11:01 PM
Bent6's Avatar
25 Year Member
Post
I think that is for the front. 75-140 is recommended for the rear.
